Is it necessary to add bleach or vinegar monthly to HVAC line when system is not in use, mainly when air conditioning and heat are not necessary.
  • Are we talking about a condensate drain line, or...? Is this line coming from an air conditioning coil or a condensing furnace, if so? – ThreePhaseEel Jan 1 at 15:08
I agree with ThreePhaseEel, no. If the unit is not in use, then there should be no reason to preventively treat the condensate drain-line.
However, you may benefit from adding water alone to the condensate drain-line monthly, if it's connected directly into the building's sewage system. If the condensate dumps outside or into a sump-pit or sink, then not even water is needed.
If you're adding bleach and/or vinegar to somewhere else, then stop it immediately as you should not be doing whatever you're doing...even if it's a humidifier. Otherwise, monthly to the condensate drain-line is not ever needed and only annually is more than sifficient.
|improve this answer|||||
The reason chemicals are added is to prevent mold growth the mold can plug the drains and some kinds are hazardous. If the air handler is not being used you don’t need to continue adding. Just a note I would not use vinegar it is a weak acid and acids will shorten the life of the coils and etch zinc galvanized coating on the sheet metal. But if the system is not being used no additional treatments are needed.
  • I was told by the builder of my home that I should use bleach or vinegar to prevent mold. It was then suggested by others that bleach is not good for the system so to use vinegar. That is what I have been using for 2 1/2 years. If I stop using vinegar when the system is running again, what do you suggest? – Rita Jan 2 at 20:47
  • I only use non acidic cleaners when cleaning coils for the reasons I provided. There are many non acid, and much milder chemicals than bleach. I even use black lights where the owners are concerned about any chemicals – Ed Beal Jan 2 at 20:58
Not the answer you're looking for?Browse other questions tagged or ask your own question.
