I've read thru some threads about garbage disposals + p-traps, and would appreciate some help. My P-trap leaks once a year (at Christmas!)
I bought a condo 2-years ago, last year p-trap started leaking when using the dishwasher. The plumber recommended a higher disposal or a shallower sink (to raise the disposal). Instead, we did a quick fix by switching out p-trap and everything was fine.
One-year later and the same issue crops up. This time, I want to fix it properly. The plumber came on the site, and it seems that height of disposal is not an issue. It's slightly higher than the drain.
It seems like I can just get rid of the extra piece of pipe, where there is extra coupling that will fail.
Thoughts?
