-1
Can I have a little advice please?
The joists run length ways, so naturally, I board across the joists.
However, the joists finish about 300mm from each side of the garage.
How should I support the board? Add a batten all around the edge?
Thanks
  • Do you have a photo? I assume you're stating that edge without support is the edge parallel to the joists...
    – tahwos
    Dec 28, 2019 at 23:05
Yes, add a batten to support any free edges.
Then plan the panel layout to maximize the use of panels ie have the fewest joints possible and the shortest total length of joints.
  • Thanks. Annoyingly, the length of the room will be about 2500 ish, so hopefully, not too much waste.
    – Paul
    Dec 28, 2019 at 19:27
  • you can order sheets in any length (up-to the length of the delivery truck). sometimes that's preferable to accepting the retail offerings.
    – Jasen
    Dec 28, 2019 at 22:56
    @Jasen that seems location specific info - 8 by 4 sheets is why the most popular van was the transit for many years...
    – Solar Mike
