I have some large cabinet doors (3 hinges on each door) which I recently installed new soft-close hinges however the left side the bottom of the door won't close and on the right side the top of the door won't close. This causes the cabinet doors to both angle and not be completely flat and aligned with each other.
Soft Close hinges from Home Depot: https://www.homedepot.com/p/Everbilt-35-mm-105-Degree-1-1-4-in-Overlay-Soft-Close-Cabinet-Hinge-5-Pairs-H1531SE-NP-U1/302854550
Is there anything I can do to get the doors to close? Do I need to bend the hinges or anything?
Additional Information
Adjusted the left / right, up / down, and forward / backward positions, but the bottom right portion of the left cabinet is still not closing and sticks out a bit and the right cabinet door on the top left isn't closing. In terms of left / right and up / down those are adjusted "correctly". In terms of forward and backward, there seems to be some deviations that can't be corrected with the forward / backward adjustments or the deviation is too much for the max / min adjustment limits.
