It’s made of a single piece of steel or a steel alloy, has a handle and shaft with a notch at the end of the shaft. I tried a google search and even a google image search using the photo below but couldn’t find it.
It is 5.5 inches (14cm) long.
What is this tool called and what is it used for?
    It’s about 5 - 1/2 inches, or 14cm.
    – ChrisB
    Dec 25, 2019 at 2:00
  • someone may have made it in a high school metalshop class
    – jsotola
    Dec 25, 2019 at 2:22
  • Context of where you found it or got it. Looks like a plug follower someone made (used when removing a lock core) to keep pins and springs in the Bible. Or it looks like a custom made tamper proof spanner screwdriver.
    – Gunner
    Dec 25, 2019 at 3:49
    the knurled handle suggests a tool for a greasy environment
    – Jasen
    Dec 25, 2019 at 5:00
It could be used for any of the following, depending on size:
  • A Schrader valve core tool, used for automotive tires (see examples)
  • A wing-nut tool, useful in tight places or to apply more force
  • A wire-wrap tool, if there is a recess at the end of the shaft
  • A tool for hand-bending metal contacts or light wire
  • It is a Shrader valve core tool. I found the model on Amazon.
    – ChrisB
    Dec 26, 2019 at 20:37
It looks like a broken breaker bar with the end ground down for some specialty job. They are manufactured by many companies but here's a similar piece about the same size or it could be a larger one cut down. enter image description here
    It’s probably not a breaker bar given it’s length of 5.5 inches. I added the length to my question.
    – ChrisB
    Dec 25, 2019 at 2:07
  • I agree, breaker bars are usually way BIGGER than your hand. 5 - 6 inches is not going to give you extra leverage over a 5 - 6 inch wrench or socket.
    – Gunner
    Dec 25, 2019 at 3:36
    It could definitely be a breaker bar, they come in all sizes. Look at the picture in the answer, that is a breaker bar. +1 Dec 25, 2019 at 19:57
  • Good guess but as it turns out, it's a Schrader valve core tool. Breaker bars can come in that -length-, but the shaft diameter on the tool in question is much smaller than this breaker bar.
    – ChrisB
    Dec 26, 2019 at 20:40
