Button naturally gets stuck like this after depressing itCorroded button
My toilet flushing button gets stuck with one button extended. It doesn’t affect the toilets flushing but it is a little ugly. I’m very new to DIY so I’m not sure if I can just scrub the blue stuff (which I presume is corroded metal?) off and then put the button back in place. Or would that just mean the button would get even more corroded.
Thanks
  • try soaking the metal in Coke ... the phosphoric acid in Coke may dissolve the corrosion
    – jsotola
    Dec 23, 2019 at 7:34
  • You could probably soak the whole thing in CLR and brush it about 2-3 rounds or find a replacement for your specific model if that's easier.
    – MonkeyZeus
    Dec 23, 2019 at 16:17
I happen to like pure silicone grease for articulating plumbing parts. I keep a jar of food grade silicone grease in the shop. Its usually sold in scuba gear shops, but I see it gaining popularity for other applications.
I'd clean the toilet flush button parts with something like CLR, lube with silicone grease and reassemble. Besides lubricating, the grease should help keep air and water off of the brass to slow down the corrosion. But it's probably time to start looking for some replacement parts.
