I have a double sink with a disposal on the right side. The disposal joins the left sink drain via a slip joint baffle tee below the left sink then the drain goes to the P-trap and out. It was installed by a licensed plumber.
Every time the disposal is turned on water shoots up into the left sink which is where we like to keep a dish drainer. What can be done to stop the water from shooting up?
