enter image description hereenter image description hereenter image description here
I have a dishwasher with a small leak where the black plastic hose coming from the water inlet valve attaches to the dishwasher water inlet (on the left side of the dishwasher body). The leak is at the location near the tip of the green pencil in the photo.
The hose is being held on by a spring clamp and it seems to be in good working order.
My question: is there a trick to stopping water leaks from this junction? Is there an equivalent of a plastic-on-plastic pipe dope that I can put on the tubing here?
The fix for this might be crazy simple: petroleum jelly (Vaseline, etc). Make sure it's the plain stuff (i.e. not medicated), then take the hose off and smear some around the edges, then fit the hose back on. It's remarkable how well it stops minor leaks like this.
    They also have silicone grease made for this, typically sold with the faucet repair items at the home store. That might be safer for more plastics and rubbers.
    – JPhi1618
    Dec 18, 2019 at 17:13
  • Actually I've used this for some amazing fixes (my wife always has a jar) and I've never had a problem with it damaging plastic or rubber. I would say it might be the safest stuff around. And it even fixed dried-out connections to boot
    – Machavity
    Dec 18, 2019 at 17:22
  • @JPhi1618 - thanks for your comment! Have you seen, by chance, if the silicone grease used in these types of repairs are also food safe? I imagine that a small amount will be washed onto the dishes as it enters with the rinse/washing water.
    – Han
    Dec 18, 2019 at 17:25
  • Cool, good to know that petroleum jelly works in practice. The internet tells you it degrades some plastics, but probably a tiny consideration in the real world.
    – JPhi1618
    Dec 18, 2019 at 17:26
    In addition to all the above good suggestions, when you remove the black hose to lube it up, examine the white piece going into hose to make sure there's not a pinhole or crack in it.
    – JACK
    Dec 18, 2019 at 21:22
