A home inspection noted that the center beam in our basement was not secured.
What is required to secure a beam to a column, and is it really required?
The house is in Oakland Co, Michigan, so not a lot of earthquakes there.
Sign up to join this communitySome are welded, by bending those "ears" or "tabs" over, others are bolted with clamps using those tabs.
Check what was specified with the architect / design engineer.
And, YES, it is required, otherwise it could be knocked over...
Simpson makes a column cap, but you’d need to cut the top flange off.
Here’s their catalog showing different sizes:
https://www.strongtie.com/lallysteelcolumncaps_columncaps/lcc-ccos_productgroup_wcc/p/lcc.ccos
