Started hearing what sounds like a popping sound coming from inside our bedroom wall. It is part of the exterior to the house, but we have no known water or air ducts along that part of the wall. Any ideas what it could be or who would be able to look at it
9
  • What type of exterior do you have? Brick, siding? Maybe a piece of siding is loose and it is being blown around by the wind. This happened to me .. but was more of a flapping sound. And clearly from outside.
    – Mike
    Commented Dec 17, 2019 at 4:36
    How often does the sound occur? Once every few seconds? Once or twice a day? Also, if you have any outlets along that wall, you can remove the cover plate and listen. Commented Dec 17, 2019 at 4:38
  • You might also have an animal of some sort in there. Squirrel, chipmunk, mouse, etc.
    – jwh20
    Commented Dec 17, 2019 at 11:27
    Hello, and welcome to Home Improvement. We'll need a lot more info before we could help you. And, you should probably take our tour so you'll know how best to participate here. Commented Dec 17, 2019 at 15:40
    The key to finding the source of a noise is the investigator. It is a super challenge for people online tell you what is making the noise. We can throw out ideas. But your investigation, to provide us with enough details, will probably identify the source. Commented Dec 17, 2019 at 20:54
Depending what "popping" (I think either popcorn or bubblewrap, neither of which seems likely) means, either:
Dripping water from a roof leak (or from a pipe above traveling a long way sideways, if no pipes in that section of wall - water will go a long way on framing)
or
Some sort of electrical arcing (try shutting off breakers and see if it stops - if it's that, the house you avoid burning down would be your own.)
