I was thinking I would replace one of our dumb switches with an Eve smart switch. I opened it up to make sure it had a neutral wire, but it was wired so poorly that as I pulled on the old switch, most of the connections came undone. In the process, though I discovered that it was a 3-way switch, and so I can't use an Eve smart switch.
So I decided to just replace the old dumb switch. But the wiring of the box is more complicated than I'd ever seen. So I'm not quite sure how to rewire it. It has three cable coming in to the box. The top-right cable has a ground, black, white and red wire. The bottom-right cable just has a ground, black and white wire, as does the bottom-left cable.
The ground wires are all connected.
The two bottom white wires are connected to each other still, though it's possible the top white wire was connected but I'm not sure - it could have been connected to the switch instead.
The top-right black wire is connected to the bottom-left black wire.
The top-right red wire is free (and so I think was connected to the switch).
The bottom-right black wire is free (and so I think it was connected to the switch).
I'm trying to re-attach a Lutron DV-603P 3-way dimmer switch. It has a ground, a black wire and two red wires. I've seen some wiring diagrams for it when used as both a two-way switch and a 3-way switch, but none of the diagrams use a 3-cable box - just a simple 2-cable one.
I tried to simply wire it up as a 2-way switch, connecting the ground, and the switch's black to the bottom-right black, and the switch's first red to the top-right red, leaving the switch's second red wire un-connected (and the top-right white un-connected as well). That didn't work, largely because I think that it should indeed be wired as a 3-way switch.
So does anyone know how I should re-wire it as a 3-way switch in to a 3-cable box?
Here's a diagram of the wires as they exist, though as I said, some of the free wires might have been attached to some of the other wires and come loose when I removed the old switch.
And here is the back of the switch itself.
Here's a photo of the box, and then a close up of the upper part and the bottom parts.
