I've recently moved house, and there is a wall lamp, see picture, which we never use, and i was wondering if i could put a usb socket there instead so i could charge bike lights and similar accessories.
Is this possible? Safe? Stupid? I have no clue, so any help would be appreciated.enter image description here
  • There are Edison A19 screw-in USB chargers (usually extending the socket for use with a bulb also) – Joe Dec 16 '19 at 19:58
    What sort of box is behind the fixture? – isherwood Dec 16 '19 at 20:00
While there are other options involving wiring, the safest option that does not involve an electrician is a light bulb to outlet adapter. Here, the version for use in countries with Edison base A19 bulbs:
Screw in outlet adapter for lamp fixture Edison base A19
Someone else can add advice for other regions. In the case of a USB socket a third prong is generally not required, though chargers in the UK generally have a plastic fake third prong anyway.
  • These things cost less than $2. There are also versions that allow you to keep the bulb socket, but add an electrical plug socket. – gbronner Dec 16 '19 at 23:59
There are several types of screw up in lamp adapters for usb charging... this one keeps the bulb socket and offers a switch for turning it on and off as well...
https://www.amazon.com/Power-LampCharger-Adapter-Charging-Station/dp/B07P9SDHRY/ref=asc_df_B07P9SDHRY/?tag=hyprod-20&linkCode=df0&hvadid=312727440900&hvpos=1o1&hvnetw=g&hvrand=16039082328258743868&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9052336&hvtargid=pla-662025529566&psc=1
