When passing a sofa through door I saw a few scratches after and even some irregularities. enter image description here enter image description here enter image description here
I know there are some pastes I can use to fix the irregularities and on the past I used some kind of varnish with color on the door.
Is it the best alternative?
I would go to a home store and look for a “scuff repair pencil” you need to replace the color first once you have it close then a light sanding and touch up varnish can hide these scrapes and scuffs. Next time you will know it is easier to pull 2 or possibly 3 hinge pins and not damage the door. Pulling hinge pins normally only takes a minute or 2 and the door is not damaged.
  • That seems a really good advice to always take the door out, about the scuff repair pencil I will search about it. – Nmaster88 Feb 2 at 22:27
