I am building 46x34 shower base using large format tile. I like it because it looks the same as the flooring. I building a curbless shower by the way.
However the plumber did not position the drain in the center so I came up with this tile pattern to offset the the larger width on the right side.
[![enter image description here][1]][1]
However it came out not that great looking.
Do you have any recommendation?
(In case you ask, I have waterproof liner behind the hardiebacker AND Redgard. The tiles have not been set yet. I just lay them into correct position for now).
Update
Here is the result. It looks “okay” unless you get 1-2 feet close to it
