You have to provision 50A for the 10kw heater. We can play some provisioning games on the saw, dust collector, freezer, lights and receps, and allocate them, say, 25-30A. Which puts us at 75-80A.
You could get away with #4Cu / #2Al wire. However, there's very little cost difference just go go all the way to 100A, and that's commonly done.
So, provision 1 AWG aluminum THWN-2 wires with a ground wire of 8 AWG copper bare or 6 AWG Al insulated. There's no reason for a wire size bump at 80'.
This setup would also have the reserve to stick a Tesla charger in there, though Tesla+heater+shop tools simultaneously would be a no-go. Presumably you don't want sawdust on your car :)
1-1/4" conduit should get it done.
Our standard advice is to use a much larger subpanel than you'd ever imagine needing. That's because "buying a subpanel with more spaces" will set you back a couple of Frappucinos, but "having to change your subpanel because you thought too small" is a solid day of work. If the subpanel is attached, even with a breezeway, you don't need a "main breaker" in the subpanel. If detached, you need some kind of shutoff switch, and using a main-breaker panel will only add $20-30 to the cost of the panel. There's no need for the subpanel size to match the feed breaker (100A) size, so feel free to get a 150A-bussed panel with a 125A main breaker if it's on sale :) Also consider "value pack" panels that come with some breakers.
