I want to use some smart switches and wanted to eliminate the use of 3 way switch in a 3 gang outlet. Can you please walk me through which wires to connect and which ones to cap.
Switch 1 - three way switch which operates with another three way switch upstairs --> this is the one i want to eliminate. I may put the a smart switch at the junction at the top of the box if this is possible.
Switch 2 - single pole switch that controls main entrance light --> this is where I have a smart switch
Switch 3 - single pole switch that controls outside light --> this is where i have another smart switch
When i opened up the box - all the neutrals were packed together. I have split them up and connected them together for switch 2 and switch 3 to work (which it does).
I also noticed that one of the black wires ran through each of the switches originally. I have now separated them between the 2 smart switches and the 1 dumb switch.
Currently, the three way switch does not work.
My question is - can i have a 1 dumb three way switch with 2 smart switches. Also, can all the neutrals be connected together to complete the circuit?
I am open to replacing the three way switch to a single pole that is simply controlled from upstairs.
Thank you.
  • Does this illuminate a stairway? Will you be able to control the stairway light from top and bottom? Dec 11, 2019 at 21:25
  • Yes - it does illuminate a stairway, but there is plenty of light and not really necessary. I don't mind if it is just controlled from one end using a dumb switch downstairs or a smart switch upstairs.
    – rdave
    Dec 11, 2019 at 21:34
    That's not your call, though. A person needs to be able to light the stairway from either top or bottom. Dec 11, 2019 at 21:38
    Can you post pictures of what is inside the two junction boxes? I.e. the wiring behind the switches and how it attaches to the switches. .. Dec 12, 2019 at 0:10
  • Can you post photos of the insides of the boxes please? Dec 12, 2019 at 2:12
  1. Yes, if the switches are all on the same circuit (breaker), you tie all the neutrals together.
  2. Yes, you can have dumb & smart switches in the same box. And receptacles. And all kinds of other things.
  3. As Harper noted, you must have switches for stairway lighting at top & bottom. So if you want to put in a smart switch for one end, put in a smart switch remote for the other end.
