I am making a steam condenser for my chemistry project, as our lab is not equipped with one. The materials I am working with are a 0.5 litre glass jar (was a honey jar) and some plastic pipe I bought from a hardware store (not sure about the material, but it is see through, and labile to heat). My plan is to have 4 holes in the jar's lid : Input/Output for the gas, and another I/O for the cooling water. The steam pipe will be arranged in a spiral on the inside, a small distance apart from the walls.
However, I am concerned about the adhesion, as it may come off under the high heat, and may be not be suited for plastic-plastic or glass-plastic-joints. Thus, I am looking for advice on which glue to use for this task. If the temp. goes above 110C, then the ethanol is on fire and giving me bigger problems.
Pipe Specs : Vinyl tubing, Inner diameter 7-8mm, Thickness 1mm
Jar Specs : Soda glass, Thickness 3-4mm, Outer is 8x8cm square with rounded corners, Height 15cm
Adhesives I currently have access to are Glue Gun Sticks, M-seal(Epoxy), Feviquick(not sure if it classifies as hot glue), and Crafting glue(Fevicol).
EDIT : I am open to product recommendations, but can only order them from Amazon and such.
Note :
- I realize this may be too much information, but I can't reply back quickly so the more you know.
- I also realize that this may not be right Stack Exchange site for projects like these, but I wanna talk adhesives and the site says DIY.
