Recently had this room plastered, then painted, and stupidly I only took the front off of the sockets instead of removing the full front socket.
This has caused a bit of an issue as the facings now don’t fit right on to the socket, I’ve accepted I’m going to have to deal with that for now.
What I do need fixed is the holes I can see behind a switch & one of the sockets. What is the best course of action here?enter image description hereenter image description here
    Does this answer your question? How do I fill holes around a light switch?
    Dec 9, 2019 at 21:27
    For someone in the UK... Are "plus sized" outlet covers common/available? In the US we have a few sizes - Standard, Midway, and Jumbo to take care of these little gaps.
    – JPhi1618
    Dec 9, 2019 at 22:00
The best approach is to fix the plaster and paint. Some other ideas:
  • Install oversize device plates. Since you have nice stainless-steel plates now, this will be more expensive, but it would be quick and easy.
  • You may be able to find or make backing plates that fit around the devices, behind the existing plates, and extend outward a small distance.
  • As a last resort, fill with spackle or painter's caulk, then touch up the paint.
  • Smooth uneven border areas
  • Mix new plaster or already mixed material
  • Apply the mix on the damaged area
  • When it dries apply a thin layer of mud compound
  • Sand, prime and paint
Hope this helps
