Need help identifying shower diverter cartridge for replacement
Do you know he name of the manufacturer?– JACKDec 8, 2019 at 2:13
i thinks its kohler but not positive– mark robinsonDec 8, 2019 at 14:42
the piece thats broken is the plastic connector between the diverter and the pull handle. i am planning to replace the whole cartridge but i want to keep the pull– mark robinsonDec 8, 2019 at 14:54
It's going to be difficult identifying that part without a model number. At this point I think your best bet would be to go to your local home store and search the plumbing section racks for an identical part. Better yet, take it to a plumbing supply store and they'll be able to match it. Good luck.
thanks, i found the diverter replacement part! thank you for your help Feb 24, 2020 at 16:03
tempress II diverter old style
Hello, and welcome to Home Improvement. Thanks for the answer; keep 'em coming. And, you should probably take our tour so you'll know how best to contribute here. Feb 21, 2020 at 18:24
