-1
In order to replace the heater element on my Miele G6510 dishwasher, I removed the whole sump assembly by removing the large worm-band and removing the filter and unscrewing the washer-jet mount. (I now know that this is not necessary - you can remove the circulation motor by just prising it out!).
When I try to reattach the sump I can not fit it over the large seal. The service manual simply says "Use rinse-agent" to lubricate it. I've tried washing up liquid without success.
I've tried all sort of ways to force it but I can't seem to apply enough pressure.
P.S. The heater element is included in the replacement part "Pump Facia"
The issue is probably that the o-ring has deformed making it impossible to refit.
Unfortunately, Miele only sells the o-ring as part of a new sump assembly, which costs over £50 and has to be ordered from Germany.
Fortunately, a British Standard 169.10mm inner-dimension, 185.90mm out-dimension, 8.40mm cross-section o-ring seems to be a perfect replacement.
One such supplier is https://www.altecweb.com/ product code: ORN-1691-84
