The apartment I moved into has a kitchen with cabinets as most kitchens do. I noticed that in the mornings it has been especially cold in the kitchen, and I traced the cold air to a large gap in the corner of one of the cabinets.
The photo below was taken inside the corner cabinet. You can see a pipe exposed. A lot of cold air is seeping in through here.
cabinet-exposed-pipe
What simple things can I do (without involving the slow-moving elderly landlord) to patch this up and minimize the amount of cold air that gets in?
  • Install literally anything that's airtight. I doubt that'll solve your actual problem, though, which is apparently poor insulation and weather-proofing in the building itself, plus a negative air pressure condition. That air will find another way in.
    Dec 6, 2019 at 18:57
Perhaps using some ridgid foam insulation board, you could build a chase inside the cabinet. If you take your time and cut it carefully using a straightedge, it should fit neatly in place by tension without having to use any caulk or adhesive that the property owner may frown on later. I would build it in an "L" shape and it shouldn't take up much of your usable storage space. Hope that helps, good luck![enter image description here]1
  • Thanks! This is what I'll do. Btw, did you use some tool to create this quick mockup or is it just a generic image from online? Dec 8, 2019 at 19:59
  • I used google sketchup, It is quick and easy. Dec 10, 2019 at 13:46
  • You said it should be able to stay in place using "tension". What do you mean by that exactly? Jan 10, 2020 at 14:32
It looks like they had to cut it out to go around the pipe. To seal this up I would get a can of spray foam and fill the gap, the foam will seal the gap and act as insulation.
