The subfloor in my home is 4" planks. The previous owner removed the hardwood, painted the flooring and left it that way (I have no idea why you would do that).
Regardless I want to put down tile. Do I need a moisture barrier between the mortar and the flooring?
FYI, I have to use mortar. Adhesive isn't an option because I'm going to be using electric radiant heat.
