I want to build a 4m x 5m raised platform for my kids fort. It will be 2m high. I have a few questions:
It is OK to attach the posts at the corners or will I need more in the middle?
What do I attach the frame to the posts with?
How far apart should I place the floor joists?
What do I attach the floor joists with?
With the floor boards do I need some space between them?
Thank you. I probably will have more questions.
    You're basically building a free standing deck. You have to follow all the rules for framing a deck - sizing joists, beams, posts, etc. etc. However you don't have a nice sturdy house to attach to - with it freestanding, the risk of collapse is far greater. Be super careful - deck collapses kill or injure more people than any other construction error. – batsplatsterson Dec 4 '19 at 9:45
grab a framing manual from your hardware supplier, it will tell you what size beams and posts are required to make a sturdy floor.
4 posts sounds workable. but yo will probably need bracing to keep the posts straight. or else use very deep holes for the posts.
Bolts of a weather resistant type eg: galvanized.
See framing manual.
Nails or joist hangers. Depending whether you want to pass the joist over the frame or butt them up-to it.
Does it rain where you live? Basically you are building a deck. The gaps allow rain to drain through the deck.
| improve this answer | |
    A 4m x 5m (13.12 ft x 16.4 ft) deck will need more than just 4 posts at the corners. + – JACK Dec 4 '19 at 13:13
