We recently moved into a new home and have been blessed with sloppy plumbing and high water pressure. The whole home is copper and since moving we have had 3 leaks in various joints. I'm no expert but I can clearly see poor soldering, overfilled joints, burnt flux, and poor clean with flux everywhere, etc...
Given the above I want to install a "smart" valve, I bought a Phyn Plus for the job. Originally, I had thought the line coming into the home was copper but after taking things apart I found what looks like PEX with an interesting PVC coupler to copper with newish looking crimped couplings. There is also no Pressure Reducing Valve so I will need to add one. At this point I'm wondering what scope of work I should ask the plumber for.
I think these are the problems: A) No PRV. I'd also like a pressure gauge to see what the pressure is on both sides of the valve. Worthwhile? B) Within the first few feet of pipe into the house I already have multiple couplers and nothing is strapped down. I'm thinking I could clean that up. C) Would it be worth going from the incoming PEX to my own new Uponor PEX run. That PVC coupler looks super sketch. This would be a good start towards repiping the house down the road.
Any thoughts would be great!
