As far as I know, their components are the EDPM/nitrile rubber inner tube, the stainless steel fittings/crimping at either end (possibly a plastic push-fit connector) and the stainless steel braid.
Provided they are stored correctly, I suspect the stainless steel components would not be an issue, but how about the rubber tubing? Does the rubber become brittle if left unused?
Is there any point beyond which you would no longer consider them safe for use?
