I’m drilling a hole into my outer wall and there is a random metal bit inside the wall. There are no studs or wires... what is it?
In the picture it is just the most bottom part of the hole ( it’s very hard to see srry )
1it is probably there to stop you from drilling through electrical wires, or through some plumbing pipe ... or it is rebar if the wall is concrete – jsotola Nov 30 '19 at 2:35
Since it’s a very minuscule piece, is it possible to make it how lower? – Sturgis Nov 30 '19 at 2:37
it looks like an old rusty wedge bolt, but that doesn't match your text. – Jasen Nov 30 '19 at 2:44
@Sturgis, ???? ... make what lower? – jsotola Nov 30 '19 at 4:07
1@Sturgis, we can't tell you if it is safe to file, because we do not know what it is ... you need to figure out what it is first – jsotola Nov 30 '19 at 8:04
If its a concrete block home it could be the rebar used to tie the roof to the foundation or a tie strap. Then again I have dropped an entire saw into a wall and had to leave it because I couldn't get it out. Someone could have also run a ground or bonding strap depending on the construction. It up to you on whether or not to cut it without looking at the entire construction.
