I recently bought a house ( about 15 years old) but just noticed that the back of the fireplace is cracked, it's about 1cm wide in the worst place. Can I repair this with fire clay/ cement? enter image description here
If i have to replace the firestone, do I have to take to whole fireplace out to repair?
Update, wider picture of fireplace enter image description here
    What type fireplace is that is it a metal top? What is it sitting on ? Concrete or a wood structure.
    Commented Nov 29, 2019 at 17:19
    Where is this? It looks like an old-style one in the UK or Ireland.
    – GdD
    Commented Nov 29, 2019 at 19:41
  • @Ed Beal I added a wider picture
    – PaddyD
    Commented Nov 29, 2019 at 20:42
    I will just leave a comment because don’t know the construction or flue type. The bottom can easily be repaired with fire clay, it needs to be worked back into the crack if that almost triangle on the right is loose I would remove that fire brick and replace the one or 2 bricks in the lower section, since there is some cracking in the back the bed or bottom is probably in questionable condition I would clean it out and pour a fresh layer of refractory cement this can be used to repoint the new fire bricks if needed , the crack going up needs to be cleaned out and sealed with clay in my opinion
    Commented Nov 29, 2019 at 21:24
    I would add I don’t see a grate this may be the reason for the crack. I have installed hundreds of stoves cleaned many more and also repaired hundreds on this side of the pond mostly in wood framed structures, stone and concrete structures are no brainers but wood structures require more care to verify the seal.
    Commented Dec 1, 2019 at 7:45
Since you have a non flammable structure, and a solid area to work with I would clean the area out both upper and lower and fill them with fire clay. Making sure to use tools to push the clay to the back. At each layer make sure to mix them , it is impossible or just about impossible to work a bead all the way back and fill the hole.
I roll out a foot or so press it on the crack then use a metal putty knife and a small dowel to push the clay to the back, then add another bead or roll and make sure to punch through to mix the layers. And keep adding until the crack is completely filled and tight so if you push in it pushes out above or below the point you are filling. To make the bead or roll I take a ball of clay and roll it in my hands until it is about 2x the width of the crack, if the crack is longer than the roll no problem make another, on the next layer try not to have the lap in the same place, it won’t matter if properly mixed but is better to have laps in different sections. I usually finish with water and rub the surface smooth, now the important part.
Let the clay dry it may take 3-4 days. Go by the instructions but most fire clays I have worked with have to dry naturally , heat during the drying process can cause a failure, there was 1 brand I used that did require heat but it offgassed a horrid smell and I never used it again, it was quick and did hold , but the several hours of chemical smell was not worth it to me. So follow the instructions on the bag.
Make sure your grate is in good condition and it should be spaced from the back , I don’t know anyone burning coal any more but if it is two close it will cause the cracking, not much of a problem with wood but it can do the same. Good luck.
