I need to replace existing gerber toe-push tub popup stopper, because the rubber gasket is worn out. Below are images of the toe-push stopper.
Click on image for a larger version of the image.
The fitting on the toe-push appears to be either 10-24 or a M5.
Below is image of of the tub drain shoe
The depth of the fitting in drain shoe is about 1 1/4 inches
I purchased Danco Replacement tub drain stopper.
Issue: The fitting the Danco replacement part is 5/16 inches or 3/8 inches. The fitting in the tub drain shoe is less than 5/16 inches. I think the fitting is may be 1/4 inches.
Anyone run into a similar issue and if so can share how the problem was solved.
What are possible alternative fittings or any another options?
Note: I also tried the PF waterworks Fits 3/8 in.and 5/16 in. TubSTRAIN Universal Toe Touch (Tip Toe or Foot Actu.) Hair Catcher Bathtub Drain Stopper in CH appear worked but the gasket was too high thus didn't to the job.
