I recently got a domestic EICR done for rental purposes. Certificate shows Satisfactory Result.
I am about to commission the fitting of a new light which will require wiring into the fuse board. Would this change to the property invalidate the certificate I currently have?
What should a qualified electrician provide for individual jobs to avoid having to do a full EICR retest every time some work is done?
(United Kingdom)
