I am trying to install wide rectangular light fixture.
Something similar to this: https://www.amazon.ca/Feit-Rectangle-Ceiling-Lighting-Diffused/dp/B00Y86OROW
I Hit a metal piece while drilling through condo concrete ceiling. Is this dangerous? Did I hit a wire? The screw is quite long. How do I recover from this?
ceiling holes metal piece
  • it's possible that you found the conduit going to that junction box , if you didn't drill through it's fine. – Jasen Nov 27 '19 at 4:33
It may be a piece of rebar, usually plumbing and wiring in a multistory building will be in a electrical / plumbing chase, not in the “floor / ceiling”. No recovery needed, I would get a shorter concrete screw it looks like you have a fairly deep hole. Those led panels are not much of a load and you should have at least 2 screws if not 4 so cut that screw down or get a shorter one.
    1 1/4" Tapcons, four of them. – JACK Nov 27 '19 at 0:36
