I'm framing my basement using steel studs. I have this sliding window on the window well (see picture) that already has a finished framing all around and is flush with the concrete wall. How do I frame around this window to be able to attach drywall to the window frame - does the drywall screw into the white portion on the window side? I don't want to remove or redo the window.
closeup corner of window full window
  • Hello, and welcome to Home Improvement. It's a little hard to tell what's going on; would you add a better picture (or two)? And, you should probably take our tour so you'll know how best to participate here. Nov 23 '19 at 19:03
  • Have added a close-up view
    – csankar69
    Nov 25 '19 at 23:25
  • Well, more would be better, but let's see if you get a good answer. Nov 26 '19 at 0:02
  • Maybe step back a couple of steps for another picture to give an overall view. From the 2nd pic, it looks like you're framing right across the window.
    Nov 26 '19 at 18:36
  • Added a picture of the full window. Ignore any metal studs you see in the previous pictures. They are just resting there and have not been screwed in yet.
    – csankar69
    Nov 28 '19 at 0:52
My thought is have the stud flush with the concrete wall. Then use pine wood to create a box from the edge of the window frame to the finished drywall edge. Then put the trim on the drywall to frame it. Creates a window box ledge for fancy stuff to sit on.
