I would like to have carpet installed in the bedroom of my basement apartment which now has a concrete floor. I don't trust the carpet guy with this part because he suggested cutting corners and just gluing it and I don't trust the glue for this application.
I was thinking to drill small holes in the strip, use it as stencil to project spots in the concrete, then drill holes with my jackhammer, set lead anchors and then attach the strip with screws into the anchors. That way the strip is as firm as it would be against an OSB subfloor.
But it also seems a bit labor intensive. Is there a better way to attach carpet tack strip to a concrete floor? Like maybe drilling holes and filling them with some kind of epoxy that nails can be hammered into? That's a little easier but not much.
