I'm putting a 56lb TV on a 20lb wall mount and attaching it to two studs with 5 screws (3 on one stud, 2 on the other). Installing the plate so it is off center would make the rest of the installation easier. My gut tells me this is a bad idea for like three different reasons.
Can anyone confirm or deny that intentionally shifting a lag bolt by an inch off stud center is a bad idea?
Thank you!
Update (and decision): The stud in question is at a 135 degree corner next to a bay window. Something I saw in an outlet hole plus holes I was drilling to check led me to believe I have a single 4" stud. I now believe that I actually have 2 or three studs next to each other.
Based on answers below, I want to hit the center of a dimensional 2x4, which is 0.75" from the edge. This actually buys me what I need. I originally thought I had to hit the middle of the 4", which is 2" from the edge. If all I need to do is hit 0.75" from the edge, that gives me an 1.25" extra inches.
