Currently plumbing a 20" rain shower (droplets + water fall). Using it with a water pump/booster.
The valve that comes with it has two 1/2" inlet which consists of cold + hot water so it's basically a 3/4" feed.
It however only has one 1/2" outlet.
So my question is does it help if i connect 3/4" pipe to that outlet after using reducer coupling? In this sequence:
Outlet > 1ft of 1/2" pipe > 10ft of 3/4" pipe > Rain Shower
I know bigger pipe helps with friction but it's of no concern here as the distance is short.
My concern is more on whether this arrangement will produce a 3/4" water flow instead of a 1/2" water flow and whether i should just go fully 1/2" in order to avoid wasting hot water that are sitting in the pipe since the flow of the said arrangement is just going to be the same as a 1/2" flow.
Thanks.
  • The reason it uses 1/2" pipe is because that's the smallest size commonly in use; not because it needs the flow. Nov 15, 2019 at 17:56
The hot/cold mixer valve and/or the 1/2" valve outlet make installation of 3/4" pipe, downstream on the run to the shower head, unnecessary; you will have no appreciable benefit from this. Also, I imagine that your "rain shower" unit has a 1/2" inlet (although you don't mention this).
Your concern about "wasting hot water" doesn't make sense to me; your proposed pipe size increase is after the hot and cold mixer...
    OP is referring to the heated water left abandoned in the pipe between valve and head. Heating that isn't free. Nov 15, 2019 at 17:57
    the extra 29 cubic inches...
    – JACK
    Nov 15, 2019 at 18:12
  • 10 feet of 3/4" pipe holds .23 gallons (about 3.6 cups) of water. Consider roughly half of that would be cold water from the mix. You can decide if that's "wasting", but personally I wouldn't lose too much sleep over it. You could make a bigger impact by taking shorter showers.
    – Jamie M
    Nov 15, 2019 at 18:17
    @JamieM He's only wasting the difference between the 3/4 and 1/2 inch pipes..
    – JACK
    Nov 15, 2019 at 18:28
    Good point, that drops it to 2 cups/0.13 gal
    – Jamie M
    Nov 15, 2019 at 18:34
