I recently purchased a house and the kitchen cabinets have particle board shelves with no vaneer or vinyl wrap. Can I just paint them or will this cause future issues?
  • a good layer of paint will prevent future problems, such as localized swelling if you happen to put something wet on the shelf – jsotola Nov 14 '19 at 4:03
  • Hello, and welcome to Home Improvement. If the answer is helpful, please click the large check mark to accept it. And, please take our tour so you'll know how best to participate here. – Daniel Griscom Nov 14 '19 at 14:37
If the shelves truly are unfinished, it will be fine to prime and then paint them. However, it is not common to have shelving with no surface protection at all (like varnish or veneer).
Put a few small drops of water on a back corner in an inconspicuous spot. If the water soaks right in, you are good to prime and paint. If the water beads up and sits there without soaking in... well then the wood is finished and should probably be well sanded (or stripped and sanded) prior to painting.
