I recently bought a home with a detached garage, and within it is an older natural gas heater that I cannot find any information on. It is hooked to the gas line and has instructions on how to light the pilot and operate it, however, I would like to clean it out first because it looks like it has been a very long time since it has been used.
It's about five feet tall, stamped LSC-25 on the front and vents horizontally through the garage wall to outside (metal circular fins).
Who manufactured this heater, approximately when was it made, and how do I go about cleaning it so that I can safely operate it?
Garage Heater LSC-25 Garage Heater Controls Garage Heater Inside Garage Heater Exhaust
I finally found the model information; it was completely covered with dirt and dust.
"Gravity Direct Gas Heater / Mfd. by LSC, Inc. Kansas City, MO / 1982"
I live in KC, so that's kind of neat that it was made here. It states that there is an optional blower... too bad it's not installed!
  • Hello, and welcome to Home Improvement. Good pictures, but would you perhaps add a side view and a view of the whole inside with cover removed? And, is there any other nameplate on it? And, you should probably take our tour so you'll know how best to participate here. Nov 13, 2019 at 0:56
  • Please use the edit link underneath your post if you want to update it with additional information. Thanks and welcome to the site!
    – Niall C.
    Nov 13, 2019 at 2:27
  • Added pics: inside with cover removed, and exterior exhaust. The side is just plain. Nov 13, 2019 at 2:31
A good way to get started with cleaning it would be these steps:
  1. Remove the whole array of front panel grills. It may be a single grill or multiple.
  2. Carry grills outside and scrub with warm soapy water. A scrub brush will work well, especially for the grill slots. A wash cloth may work best on the large flat areas.
  3. Spray down the grill(s) using garden hose to flush away the soap and loosened dirt. Set grill aside to fully dry.
  4. Use a vacuum cleaner (shopvac if available) to clean up the dust, dirt, pet hair, and other debris in the furnace enclosure itself. A brush attachment on the end of the vacuum cleaner hose can help a lot on the irregular surfaces. Once the major stuff is cleaned then a damp wash cloth can be used to wipe down the inner surfaces of the furnace.
  • Do you not think it's necessary to remove the exhaust vent cap (outside) and clean the inside of the vent? Shop vac should do the trick inside the unit, thanks! Nov 13, 2019 at 1:39
  • Absolutely. You should also try to disassemble the burner units and clean and inspect those as well.
    – Michael Karas
    Nov 13, 2019 at 4:22
