We wanted to install a security camera in the front porch and as a component of that we needed constant power to the front door which is currently controlled by a light switch.
That light switch was 1 of 3 and was the right most. The middle was a 3 pole switch and the third was a regular light switch. We removed the first switch by connecting the hot and line switched to each other. There was what we think is a ground attached to the side of the switch but when it was all completed. Only the front light had power. All the rest of the outlets and switches in the circuit had none. Any ideas where we could have gone wrong?
Image of the switch we removed and its wiring
Back of the switch we removed with what i think is the ground wire disconnected
