I have double hung sash window, is there any way to prevent the top from being moved down? A different style of window hardware possibly?
As of now I have a crecent style fastener in the middle, that will allow both the top and bottom to separate if unlatched.
They are wood sash windows, with a sash chord, and are approximately circa 1922.
10
  • Are these sashes vinyl? Wood? Are you looking for a permanent or temporary solution?
    – IronEagle
    Nov 7, 2019 at 17:38
  • If they're wood, a temporary solution would be a sash spring bolt.
    – IronEagle
    Nov 7, 2019 at 17:43
    The usual solution is to drill a hole thru the upper sash into the (vertical sides) of the frame and stick a bolt in there. Nov 7, 2019 at 18:27
    you can use a shim or long dowel to wedge the top half open from the side, typically without blocking the bottom pane. You can also get locks that work on the top or bottom of the frame.
    – dandavis
    Nov 7, 2019 at 22:02
    @A.I.Breveleri, trying to keep the upper window stuck closed, so that only the bottom can freely move up and down. Nov 10, 2019 at 2:05
Here's what the previous owner of my house did to prevent the top sash from moving: Painted it liberally. They will be sealed and painted shut. You could also use caulking. They make clear caulking too so it wouldn't be noticeable, or in case you have bare wood still that has survived unpainted for the past 98 years. As an added bonus that would keep the drafts down a little too!
There are control devices that restrict the upper or lower sashes in double hung windows.
Here’s one style: https://www.amazon.com/Double-Hung-Window-Opening-Control-Device/dp/B00XLV923G/ref=asc_df_B00XLV923G/?tag=hyprod-20&linkCode=df0&hvadid=198095900368&hvpos=1o18&hvnetw=g&hvrand=17549082380206194677&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9033075&hvtargid=aud-799728744414:pla-349410125410&psc=1
If you use these, they can be removed later.
  • Security latches prevent the window package from providing an opening larger than X. They restrict both sashes; the OP wants the lower sash to still be completely operable.
    – Mazura
    Nov 14, 2019 at 0:50
