I am adding a master bathroom shower, toilet and double vanity to an abutting wall of a full bathroom, Is this wet venting good if I tie into existing 2" shower vent in the shared wall?enter image description here
  • Hello, and welcome to Home Improvement. I'm no pro, but I'm guessing you'll have venting problems there. And, you should probably take our tour so you'll know how best to participate here. Nov 7, 2019 at 15:02
Found this at https://inspectapedia.com/ Which references Maryland plumbing codes. You should check your local code for what's appropriate in your situation.
The second table, which shows trap-vent distances says that for a 2" trap (shower) the maximum distance to the vent is 5 feet. You're way over. It also specifies a minimum vent size of 3"
