I'm trying to finish an en-suite bed/bath that currently has a capped 8" rigid duct coming off the main trunk. What is the proper method to supply air to both the bedroom and bathroom?
The bedroom is about 135 sq-ft and the bathroom is about 35 sq-ft. Can I just split the 8" rigid into two 6" flex? Or do I need to come off the trunk line with two 6" lines, one for the bedroom and one for the bath?
Thanks in advance!
    Hard to say without knowing more about your HVAC system and home. Are the other rooms fed with discrete 8" ducts?
    Nov 6, 2019 at 21:19
    Definitely use flex only where necessary. It adds quite a bit of resistance to the line. Semi-rigid is better than the light foil stuff, and rigid isn't that difficult to work with anyway.
    Nov 6, 2019 at 21:20
  • We need to know: HVAC system size in Tons, size of each return and their location(s), room sizes, size of all branches/outlets to give you a reasonable answer. Do you know why that rigid was capped?
    – peinal
    Nov 6, 2019 at 21:48
  • Hello, and welcome to Home Improvement. We'll need to know more info before we can help. And, props for taking our tour before posting; few newbies do. Nov 6, 2019 at 22:00
  • Is there a reason using rigid ducting for the branches isn't an option? Nov 7, 2019 at 1:03
Yes splitting an 8” duct to 2 separate 6” ducts is an appropriate size transition, since it is a master the air will be going to the same areas while the bathroom door is open. I usually add dampers to all my vents it costs more but makes balancing easier.
