I believe the low pressure from my kitchen faucet hot and cold is from this blue connector. The faucet and parts are new. If I disconnect this, the pressure seems normal, but with it connected it seems to have a very spread spray which is what’s probably causing the low pressure. That’s not normal right? I will probably try to replace this connector even through it should be new.
1 Answer
I fixed it. Inside the connector there is a flow restrictive: I popped it out and needed a needle to pick some particles out. My hot water tank probably needs a good flushing. But the flow is fine now.
Aw crap. That's what I was going to suggest. But, really great job and thank you for getting the information on here.– IggyCommented Nov 4, 2019 at 4:48
