I have a model #GEE-B10-10 Grounding Clip that I'm not sure how to install. Does the long leg go on the outside or on the inside of the electrical box?
profile pic of grounding clip
Long side:
long side of the grounding clip
Short side:
short side of the grounding clip
    Your picture doesn't show it but normally one side has a groove where the wire rests when clipped. That side would go inside the box then, yes? Nov 2, 2019 at 1:12
  • Jimmy Fix-it I added more pics. So the long side goes in the electrical box and the wire get bent down on top of the long side, correct?
    – Laxmidi
    Nov 2, 2019 at 14:58
I contacted the company. The long side goes inside the box.
On yours the short side goes inside the notch jimmy is commenting on is the tab the wire is held under that. That angle is hard to see but the ones I use loop a bit further.
  • This answer would benefit from breaking the first sentence into three. I had a lot of trouble figuring out what you’re trying to say.
    – prl
    Nov 2, 2019 at 11:31
  • Ed, Thanks of the comment, but I didn't understand. I've added more pics.
    – Laxmidi
    Nov 2, 2019 at 14:56
  • The short side inside the box. The long side is flat it goes on the outside.
    Nov 2, 2019 at 15:37
