What material is this fake wood? How can I fix the crap that's been chipped off?
It’s crappy fake crap paneling. Lowe’s sells some of this crap maybe you can match crap for crap and replace a sheet. Otherwise clean prime paint over it.– KrisOct 28, 2019 at 23:07
1@Kris Depending on the thickness of the part that came off, might need to sand all the "edges" before priming.– manassehkatz-Moving 2 CodidactOct 29, 2019 at 0:14
This is a dumb question but what's the best way to find out what material this is and which would be a best replacement?– Brett LarsonOct 29, 2019 at 16:09
@BrettLarson, find an inconspicuous or easily patched area and cut or drill a hole in it. Using a hole saw, you will get a circle of material to inspect and shop around with.– JPhi1618Oct 29, 2019 at 18:09
How thick is that area it could be a veneer and it can also be a paper product, it looks like pine , but if a paper it may be better to make a wainscoting to hide the lower level. Is their a sink or tub on the other side of that wall? Stopping what caused the damage in the first place is going to be job #1.– Ed BealOct 29, 2019 at 20:08
Add a comment
