I'm currently using a 3/4" x 1/2" bell reducer and 1/2" nipple to connect my tub faucet's inlet flare (I think that's the right word?), but no matter what I do, I'm getting leaks on both ends of the reducer. Per the picture, I'm using PTFE tape.
Is there a way I can directly connect the braided connector to the inlet flare? The faucet also came with a riser nut with a washer inside which I'm currently not using.
You need special adapters built for older tubs that use the old style bathcocks. If you go to a plumbing shop (not big-box hardware store) and ask for "claw-foot tub faucet adapters" they will probably know exactly what you are looking for:
| improve this answer | |
  • Also, nicer looking. There are a number of online “fancy” versions available for visible plumbing. – M.Mat Oct 28 '19 at 5:39
