I have an electric drill without a feature to adjust its torque. Because too many bolts and screws to fasten as quickly as possible, I need an electric screwdriver.
Using a screwdriver bit directly connected to the drill is very risky because the excessive torque might damage the screw head, etc.
Question
Is there any trick to solve this problem with at most $30?
You could use a drywall screw adapter:
This one is for drywall. It does not limit torque, instead there is a clutch inside which disengages when the metal "tube" around the screwdriver bit in the center hits the workpiece, and that prevents screwing all the way through the drywall. It works pretty well, with reasonable accuracy. You can also change the drill bit, so it is not limited to drywall screws.
If you have a zillion drywall screws to install, rent one of these.
I think you can also buy torque limiters for your drill. That will probably be expensive.
Note standard AC mains powered electric drills aren't well suited as electric screwdrivers, because they generally use triac phase angle dimmers which have about zero control at low speed, also they're way too powerful and have lots of rotational inertia which means it's almost impossible to stop when needed. Battery powered drills are much better, the trigger has much better torque control usually.
EDIT Here's a neat video.
https://www.youtube.com/watch?v=2R7klA7Cc80
Cheaper models don't have a clutch so they just make the bit cam out of the screw, which works with Philips (drywall) bits which are designed for this, but destroys other bits (PZ, Square) pretty quick... that's inconvenient. The one in the video has a clutch, that's what makes a "bbrtttt" noise when it disengages. So it would work with PZ bit wood screws, which is quite convenient for OSB floor panels...
    Thank you very much. It is very useful information! Oct 26, 2019 at 12:02
    Thanks! I've added a video link.
    – bobflux
    Oct 26, 2019 at 15:57
They make variations on drills called "drill-drivers" specifically for this purpose.
However, having done tongue-and-groove roofs using screws, in cases where plunge depth really mattered, I prefer a speed wrench and a bit holder.
enter image description here source
In my case the other advantage also lets you use the drill for pre-drilling holes so things don't crack.
