I was recently pulling weeds and I noticed that there is a hole at the bottom of my concrete stoop. I'm not quite sure on how to address it. I'm pretty handy so I'm sure that this can be tackled without professional help (and prices). Can anyone point me in the correct direction?
That's not a hole. That's just the bottom. Steps like this are poured on the dirt, and while the dirt level probably should have been flatter and lower (for aesthetic reasons), this isn't a structural flaw.
Attempting to patch it will make things worse, visually speaking. Put some mulch over the bottom edge or raise the soil level a bit and be happy.
This makes sense. I will put some dirt over it and plant something to hide it. Thank you! – gmalenko Oct 26 '19 at 13:41
Plant grass! Just get a section of sod (dirt plus grass) and plant.
If that was mine, it would bug me every time I saw it. I would dig it out a bit, cut a piece of plywood to act as a forming piece, stuff in a little gravel and pack in some concrete in two stages, using the plywood as a form and a few bricks to hold it in place. Good luck!
1And that would all fall apart inside two years. Vinyl patch might hold longer, but either is going to look like a patch until it breaks loose again. – isherwood Oct 25 '19 at 18:34
1@isherwood I did one on a bay window slab in /around 1985 and it's still holding. Maybe just lucky. – JACK Oct 25 '19 at 19:00
