A buddy and I are planning up doing a complete electrical service upgrade as he currently has and outdated fuse panel. The plan is to update him to a 150 amp breaker panel. I am comfortable with the work but while I was out pricing materials I was bombarded by a store employee on tons of code changes and needing the breakers that cost $50 apiece, making me second guess the job as I don’t want to start and get slammed with code violations. I just want to know what I should be prepared for as we weren’t planning on pulling new unless it was needed as some is old KT wire and some Romex. Any on-site would be greatly appreciate.
  • Unfortunately your question is too broad for our Q&A format. Take the tour to learn about that. If you'd like to revise to ask about the breaker thing, please provide more detail. Yes, arc-fault breakers are required in many areas of the home now.
    Oct 24 '19 at 19:14
  • Ok where would I need ark fault breakers as I’m not very familiar with them?
    – Richard
    Oct 24 '19 at 19:28
  • Whether you need to use the new expensive breakers, or can be "grandfathered" and still use the old simple non-GFCI/AFCI breakers depends on whether your local permitting authority considers this a simple panel replacement (other upgrades not required) or if it's a full remodel, where they would require you to bring it in compliance with modern code. Since you're also upgrading some K&T in addition to replacing the panel, I'm guessing they're gonna make you update everything, but you'd have to talk to them to know for sure.
    – Nate S.
    Oct 24 '19 at 19:31
  • Richard, please don't ask questions in a comment. If that's what your post here is about, revise it to make it so.
    Oct 24 '19 at 19:46
    Why are you upgrading to 150A, specifically? There's really no point in it, considering it's squarely in between standard meter socket/utility service sizes (125A and 200/225A). Also, can we have photos of the existing fuse box and metering setup? Oct 24 '19 at 23:03
Please, get a BIG panel.
The #1 panel issue we here is "my panel is full". This is an absurd problem to have given how panels are priced. The incremental cost for more spaces is a buck or two per space. So max this out.
Get a 42-space panel. No compromises.
That is the minimum sensible size for a modern home. This panel will assure you never have the "my panel is full" problem - which the next size down, a 30-space, can't promise. Even if you're at 8 spaces now and 18 seems huge, trust us. Get a 40/42.
We mean spaces, not circuits. The "circuits" number is completely useless because it relies on "double-stuff" breakers, and those are not available in GFCI/AFCI (big problem!)
If physical dimensions are a factor, look at Square D "QO" or Eaton "CH" which have more compact breakers, and put 40 spaces where others put 30. This is not double-stuffing.
Better ways to get a 150A main breaker
150A/42-space panels are rare enough to not bother looking for them. You're better off with a breaker panel "Value Pack" that tosses in some bonus breakers.
If you have a main breaker upstream (e.g. at the meter) then the new panel doesn't even need one. If this will be the main breaker, you have two ways to get a 150A panel in many panels:
  • If it has a main breaker larger than 150A, you can swap it out.
  • If you buy a convertible main-lug panel (which has space for a main breaker) then obviously you can select 150A.
Store advice
Never talk to a Home Depot, Lowes, Menards etc. employee again. Their advice is worse than useless. Electrical supply house managers tell me they visit those stores and hire away anyone good.
GFCI/AFCI breakers
If all you're doing is replacing the panel, there's no requirement to fit all AFCI/GFCI breakers. This is because of the concept of grandfathering. You would be required to do that if you remodeled or significantly altered the circuit, and that is irrelevant to whether you upgraded the panel. Your ability to do this in the future is one reason you need a big panel. They don't make double-stuff AFCI/GFCI, and they never will.
