My garage door opener stopped working and I found it's because of the sensors. It's a very old unit from the late '80s. Sears brand, not even Craftsman.
My concern is, since this is a very old unit, they obviously don't sell the original sensors anymore. Searching online, the advice is to go with Chamberlain or Craftsman brands since they're compatible.
However, the wires connected to my garage door sensors are green/yellow, and the newer brands connect to black/white wires.
If I buy the Chamberlain sensors, would they even work if I try to power them with green/yellow wires? If not, what can I do besides needing to replace the whole garage opener? Thank you, any help would be appreciated.
and-
. Simply connect the+
wire on the new sensor to the+
screw on the old connection and the other wire to the other screw. Color of insulation is irrelevant to the flow of electricity inside the wire. When you're done, wrap a bit of green & yellow electrical tape (as appropriate) around the new black & white wires to help out the next person who has to work on this. – FreeMan Oct 23 '19 at 15:45
