I tested some dust for lead using a 3m lead check swab. The test was negative, and I left the testing fluid on the surface for several days because I hadn't gotten a chance to clean it up. I know it was orange minutes after testing, and also orange a couple days after testing. It's maybe a week after testing now and I just found that it has turned pink. Does this mean lead is present?
The 3M site says this
3M™ LeadCheck™ Swabs have no shelf life. Unless the ampoules/vials are cracked, they will have an indefinite shelf life.
In other words, once the vial is broken (which you did to use the tester), it does indeed have a shelf life
  • I agree, if the op is concerned scuff the surface a bit deeper and retest with a fresh kit, their may be 2 or more layers of lead free paint on top depending on the age of the home and how often it was painted.+
    Commented Oct 23, 2019 at 14:20
Not necessarily, it probably means the fluid has oxidized over time.
The fluid is only good for 30 seconds. After that, whatever is says is meaningless.
