I bought a new gas dryer and am trying to connect it to an existing gas supply point in my laundry room. The gas supply pipe ends with this 15/16” brass MIP piece:
I already bought a BrassCraft flexible gas hose that has 1/2” MIP pieces on both ends before discovering that I can’t connect that to my gas pipe.
I did some online search for adaptors that I could use in this situation, but couldn’t find any suitable ones.
Can you please advise what kind of adaptors / hoses I can use in this situation?
P. S. My dryer has standard 1/2” MIP gas inlet.
Remove the flare fitting from the 1/2" pipe and get a 1/2" hose with 1/2" FIP fittings on each end similar to the hose pictured below. If there isn't a gas shutoff valve for that section of pipe, you'll need to install one. Use pipe joint compound or gas rated Teflon tape.
Many locations do not allow people to connect their own gas appliances but require them to contact the gas company for the installation. This is for your safety. Even if it's not required it's a good idea to have the gas company do it. They will check for leaks and the safety of other connections.
